Old 22nd July 2013, 01:19 PM
Davie b Davie b is offline
Default Cruise control ...what next
Hi guys,
I've been having problems with the cruise control just not working , I tried the move the switches aggressively whilst swearing at it fix , but that didn't work .
I then bought a replacement stalk from a8 parts on fleabay , put that in and it still doesn't work , so what next ????????
Old 22nd July 2013, 01:46 PM
What model and year?
Old 22nd July 2013, 02:06 PM
Originally Posted by hpsauce View Post
what model and year?
s8 d2 1998
Old 22nd July 2013, 02:14 PM
If it's a PF, which it probably is, replace the cruise unit box.
I did that on my old (PF) S8 with excellent results. Thread here somewhere about it....
I spent ages analysing symptoms trying to decide if it was the box or the stalk. Eventually decided on the box (failed caps are a common problem on other Audis with the same system) and got one from A8parts.
Local VAG independent did the job as it's a bit of a PITA being at the very bottom of the box of electronics modules under the bonnet.
Old 22nd July 2013, 02:21 PM
Cheers mate ,
It is a PF , I've emailed a8 parts any way just to see if it was tested prior to selling
Old 22nd July 2013, 02:38 PM
Is there a way of testing the cruise control module through vag-com , I don't really want to go to all the trouble of changing it just to find out the stalk switch is faulty
Old 22nd July 2013, 02:59 PM
No, it's a very dumb bit of kit in that sense.
What symptoms do (or did) you get, or is it totally non-functional?
My various comments are spread throughout this thread: http://forum.a8parts.co.uk/showthread.php?t=113
Early, to comment that my PF stalk was replaced (years ago) and that fixed the problem at the time.
Later, an intermittent/degrading fault eventually solved by replacing the PF control box.
Finally, a variable problem on my FL S8, fixed (largely) by "abuse" of the switch (FL has no separate box, being fly-by-wire).
Old 22nd July 2013, 04:01 PM
It's totally non functional , indicators / lights work , just no cruise
Old 22nd July 2013, 04:28 PM
Well, apart from wiring, there's not much else to replace so get a new control box.
