VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
Last night driving back from work and engine missing started again, instantly thinking fuel pump as the exact same issues as before. Obviously laptop was flat so dumped the car at work. Just plugged it in and i have a few faults.
16684 multi cyl missfire, 89 cyl 5 miss, 90 cly 6 miss & 91 cyl 7 miss I realise that these cyl's are all on the left hand bank 17913 Can anyone help? I'm showing 1/2 tank of juice but i'm going to put a couple of jerry cans in at lunch and see if it makes any difference as i have had similar before at just below 1/4 tank causing the same problems. However i get issues with engine start block by immo and i never changed the wire just put up with it, i get over it by just turning the ignition on and off and back on untill the immo light goes out, lastnight i took a long time (worst it's been for a long time) and took about 5 mins to get it to go out. I noticed that when it did fire up my fuel had dropped from 1/2 to half way between 1/4 and 1/2 and then when running all be it really lumpy it started to rise again, i now have 1/2 a tank.
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. |
Man that sucks.
Sounds like a fault common to the running of that bank, so I would get the lappy on it and see what the short term trim is like, if it's maxed out rich then I would suspect an air leak somewhere. The electrical gremlins are a worry though. Hope it's an easy fix for you. |
![]() Quote:
![]() Quote:
Have a read through this to understand a bit more. this is a good idea on how to logg data from various elements of your engine. For vacuum leaks they will be most prominent at idle where the vacuum is strongest due to the throttle plate being closed. If your results do point towards a leak they can sometimes be found by sparying carb cleaner around the hoses and intake. http://www.youtube.com/watch?v=zzEnkq9oSps |
OK thanks, however she'll not start now, it almost catches and then just turning over without firing. No faults found. I'm stumpped
![]() When doing an output test on the engine should i be able to hear ticks or click when cycling through the injectors? As i don't hear anything. Fuel pump deffo hums when the ignition is first switched on, but can't tell if there is fuel getting up to the rail or at what pressure it's at. Does smell a bit like unburnt fuel from the exhaust so i'm thinking there is petrol getting there it's just not firing.
Ignition amps were common failings on the ABZ's.
There are 2 of them, 4 cylinders each. Drivers side of the engine bay under some plastic trim just past the bulkhead iirc. Swap them over, see if the fault moves (if it'll crank at all) You should hear clicks from the injectors, but its a very quiet click, and generally they dont fail, or at least not enough at once to stop it firing....
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Thaks Ian, i have swapped the amps over to try and move the missing to the other bank, but i can not get her to fire up. So VagCom has no faults to show.
Sounding like a very, very long AA relay home
Whats the 17913?
I googled it and its a code related to closed throttle postion switch not closing, was that a fault listed in your vagcom results the first time round? |
Yes it was, i cleared all faults and nothing has come back. I looked for it in the vagcom wiki but nothing found. I'm going to google now as i don't even know what or where it is.
Its the sensor on the throttle body, other stuff I have read about it say the throttle body just needs a clean but I think that would not be the case with your problem.
