Old 13th December 2013, 08:47 PM
a8starr a8starr is offline
Default Faint buzzing noise coming from the rear.
A few months back I noticed a faint buzzing sound whilst sitting in the back. Now that I know the sound I can always hear it whilst in the drivers seat.
I notice the buzzing sound starts at around 58-60mph.
The pitch of the buzz increases with speed.
The buzz sound doesn't change when the road surface changes. It's a very consistent sound.
I have read around and gathered that is could be the tyres, wheel bearings or fuel pump.
What are your thoughts?
Old 13th December 2013, 10:58 PM
Do you consume a lot of cabbage?
Old 14th December 2013, 10:03 AM
It could be.. If the noise gets worse or better when you turn left or right, then id' suspect a bearing. Could be tyre noise.
Or... it could be wind noise somewhere.. check the seals, etc.
Old 14th December 2013, 10:21 PM
Wind noise
Old 16th December 2013, 10:00 PM
Took it to a garage today. Mechanic came for a test drive. He couldn't hear the noise. Had it put on the lift and inspected underneath. No leaks.
They didn't even charge me!
I do need to replace front tyres.
Could front tyre noise resonate through the car to the point it sounds like it's coming from the rear?
