Old 26th December 2013, 09:51 PM
SilverS8 SilverS8 is offline
Default FL Audi S8 left side hub part no.
Good evening.
I need a new hub since the aluminium that clamps one of the control arms are broken off and not sure it will last another year(so far so good)
But when checking ETKA there are several different hubs for the facelift and i can find the one i need. ( I have Brembo's)
The choices are
4D0 407 257 K (etka says for model PR-1LT?)
4D0 407 253 (Erka here says its for 6-8 cyl but no mention of S8)
4D0 407 257 AD (For cars with 20" wheels) so prob not this one
I have sourced a used one that seller claims is the correct for my S8.
Part no is 4D0 407 257 0. Other no's he found on it was
A.S 2.1
+GF + HE
K1373
Appreciate any help
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 26th December 2013, 10:27 PM
Whats the part number on your original hub?
Another way you can narrow it down, is to look at your option codes on the boot sticker or in the service booklet. For example mine is 1ZL (Disc brakes, front), so I guess I can chose any of the housings that fit this code?
1 4D0407253 wheel bearing housing left front 82MM / PR-1LT,1LX
(1) 4D0407254 wheel bearing housing right front 82MM / PR-1LT,1LX
(1) 4D0407257AD wheel bearing housing / f. vehicles with wheel disc: left front 92MM 20" / PR-1LT,1LX
(1) 4D0407258AD wheel bearing housing / f. vehicles with wheel disc: right front 92MM 20" / PR-1LT,1LX
(1) 4D0407257R wheel bearing housing / F >> 4D-1-006 000* left front 82MM / AKF:1LX
(1) 4D0407258R wheel bearing housing / F >> 4D-1-006 000* right front 82MM / AKF:1LX
(1) 4D0407258AD wheel bearing housing / F 4D-1-006 001>>* right front 92MM / AKF:1LX
(1) 4D0407253A wheel bearing housing left front / PR-1ZL
(1) 4D0407254A wheel bearing housing right front / PR-1ZL
(1) 4D0407257T wheel bearing housing / f. vehicles with wheel disc: left front 92MM 20" / PR-1ZL
(1) 4D0407258T wheel bearing housing / f. vehicles with wheel disc: right front 92MM 20" / PR-1ZL
(1) 4D0407241J wheel bearing housing / with: / wheel hub / for special armoured vehicle left front /
(1) 4D0407242J wheel bearing housing / with: / wheel hub / for special armoured vehicle right front /
(1) 4D0407241P wheel bearing housing / with: / wheel hub / for special armoured vehicle / (for modified vehicles) left front /
(1) 4D0407242P wheel bearing housing / with: / wheel hub / for special armoured vehicle / (for modified vehicles) right front /
(1) 4D0407257AD wheel bearing housing / F 4D-1-006 001>>* left front 92MM / AKF:1LX
Old 4th January 2014, 09:09 PM
A.S 2.1
+GF + HE
K1373
Appreciate any help
Had a look at the one on my car today and the only difference to the above is
mine has A.S 2.0 and not A.S 2.1 other then that all's the same.
Anyone has any idea what the difference is?
2000 Silver S8
