Old 5th February 2014, 10:47 AM
Conquistador's Avatar
Default Where is my diagnostic port?
Can someone confirm where my OBD2/diagnostic port is?
Is it behind the ashtray in the front or under the steering wheel?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 5th February 2014, 10:49 AM
Should be under the steering wheel.
Old 5th February 2014, 11:57 AM
Under steering wheel.
It clips to the steering wheel's bottom trim, so if there is nothing you will have to undo two screws behind the Alu trim, one on each side of the wheel
Trim, just pull it, difficult to break it really.
Last two screws for this job on side behind the fuse box trim
There is more screws but don't needed for clipping obd port back in
Old 5th February 2014, 05:36 PM
mannyo mannyo is offline
its right down by your feet, if you feel around the lower dash trim you should find it.
Manny
Past
Old 5th February 2014, 05:53 PM
Yeah, sorry, closer to your feet than to a steering wheel
just on the edge where the trim under steering wheel is.
Recently I was thinking about moving it somewhere less annoying as its only a harness clipped to the trim.
It can be so awkward when you have to plug the cable in from outside with closed door and window down (often during calibration or lowering suspension)
There is a little compartment on the bottom right from the steering wheel which you can open and close. I was thinking to fit it in there.
It can be so annoying when you have to plug in and out many times.
Old 5th February 2014, 06:14 PM
Been thinking the same thing, and now with the imminent realease of this perhaps more reason to move it and have it powered only when ignition is on, Thinking along the lines of Mimicsx2 so there is permanent diagnostics in the car, or just use my Android Torque adaptor instead.
Old 5th February 2014, 06:42 PM
Come on, another investment/upgrade for this year
Del, you know what, I like the way you thinking. Mimicsx2+android phone+Hex-Net= ultimate in car diagnostics. No need to carry a laptop in the boot everywhere you go.
Something to think about. From my understanding it is possible, isn't it???
Let say you move the port to that compartment which I think is ideal location, then plug and keep there Hex-Net and Mimicsx2 will display VCDS Mobile running on your phone on the actual MMI screen ???
The new RossTech product is not going to be cheap, there are two versions. One is limited to being used with just 10 VIN codes, so enough for a home user to last a good few years and a pro unlimited version. The 10 VIN version is going to be USD399 and the pro version USD499.
On the other forum I moderate, Rosstech have been participating in a product discussion.
Manny
Past
Old 5th February 2014, 06:46 PM
Thats what I'm thinking
Care to share?
