Old 12th February 2014, 04:51 AM
Default S8 Rear parcel shelf removal.
Hi chaps.
I've just removed the rear seats on my S8 and want to remove the rear parcel shelf. How do I do it?
Steve
Old 12th February 2014, 06:06 AM
Norretal's Avatar
Norretal Norretal is offline
Which model is your S8? If it's a D2 it's relatively easy because even I managed it If you confirm it's a D2 I'll send you the instructions that I used
Audi TT - 2015 - Ultra
Old 12th February 2014, 12:02 PM
Norretal, I would be interested in this as well. Mines just a 3.7 D2, but was thinking of retrofitting rear blind. My main problem is whether I can undo the speakers first from the boot. Not a big issue for most people, but I have a 125 litre gas tank sitting there.
Old 12th February 2014, 12:42 PM
Norretal's Avatar
PM sent
Old 14th February 2014, 01:53 PM
Sorry for not replying sooner. Yep, mines a D2. Any Instruction would be worthwhile. Thanks.
Old 16th February 2014, 05:18 PM
Norretal's Avatar
Apologies for MY late response, been away since Friday, will send you some instructions tomorrow
Old 17th February 2014, 12:27 PM
Got your message. You're a gentleman, sir.
Old 17th February 2014, 12:30 PM
Norretal's Avatar
No problem, hope it's useful. If I can do it anyone can
Old 25th April 2015, 10:38 AM
oldnick oldnick is offline
my rear parcel shelf speakers don't work [ D2 FL ]
how easy are they to remove from the boot [ no gas tank, lol ] I don't have the bose amp so presumably there are amps in the 4DO 035 401 25Y 's fitted ; taken one cover off but screws look impossible to get at !
in the short term would be happy to just disconnect [ I think they are causing a parasitic drain ] but can't see how to get at the wiring
Old 25th April 2015, 10:53 AM
I had at least one of mine out a while back, IIRC there's something you loosen and/or or a catch swivel away then they turn slightly to release from captive screw heads.
Wasn't that easy to get at though and I was lying on my back in the boot with a bright light to see how it all fitted. But I'm pretty sure I didn't take anything off from inside the cabin to do it.
I think I was doing multiple jobs, triggered by fitting a ski hatch so had already removed some trim and the speaker covers.
Then I decided to investigate why my rear speakers (non-Bose also) were so pathetic - I wasn't even sure they worked at all until I played some orchestral music (Mahler) and stuck my head in the boot.
The answer by the way is that they just are crap.
So I've adjusted the bass boost and fader settings on the RNS until they suit me - a fair bit of rear bias required plus a bit of extra bass to get those woofers rumbling!
Along the way I worked out roughly how the amps and wiring are set up; I think I noted some of it in a thread here, probably almost 2 years ago now though.
