Old 28th February 2014, 07:38 PM
MAM MAM is offline
Default Buzzing from engine bay
My car has developed a buzzing over the last couple of days. I could hear it from the cabin but, but when I opened the bonnet, the sound was much louder.
I have found the location, but I have no idea what the part is.
I have a 4.2 Petrol non-FSI engine. The part is under the rear engine cover and is like a disk that has a pipe up to it, and a pipe coming out of the side. The noise is like a high-pitched vibration. If I hold the part I can stop the sound - but what is this part?
edit - If my explanation is not good enough, here is an image
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
Old 28th February 2014, 08:08 PM
PCV valve by the looks of it, probably leaking due to failed diaphragm. Easy enough to replace.
Old 28th February 2014, 08:27 PM
I concur - may also be gummed up. Changed the one on our a6 a year or 2 back. Not too horrific on price from memory
Old 28th February 2014, 08:35 PM
About £25 including shipping from the USA for one I replaced a while back (on a D2).
I then dismantled the old one and cleaned it, so I have a reasonable spare, though the diaphragm isn't perfect, but does work OK.
Had to buy a tool to unclip it. Clic-R pliers I think they're called.
Old 1st March 2014, 06:17 AM
MAM MAM is offline
Thanks - I'll get one ordered, looks fairly easy to replace.
Old 4th March 2014, 08:19 PM
I had exactly the same problem just fixed it 7 days ago.. and on shutting down the engine it hooted.
Solution ...
A flat head take off the jubilee clips and then separate the casing and simply scrub all parts and spring ect with hot soapy water ..
Dry it out .. re assemble and lube up with WD40
And problem solved
I guarantee it will work !
Old 21st May 2014, 05:42 PM
MAM MAM is offline
Well, as the car was in for its alloy refurb and it was spending a week on jacks, I got the garage to replace the valve.
All is much quieter now. It is surprising how little it takes for you to question it an A8, when in many of my other cars, it just happens to be one of many noises, and sometimes these things go unnoticed.
Old 5th September 2017, 03:30 PM
lackovicj lackovicj is offline
apparently is a crankshaft vent. I replaced my one 2 weeks ago as i couldn't listen to the whistling noise anymore...it sounded like AC on full blast. Easy to replace at £23 cost.
Audi A8 D3 2003 3.7 V8 petrol, Oyster gray with black interior
19" alloy, Sport suspension transmission and seats, HID headlights, Phone in armrest, 4zone AC, Sat-Nav, TV, Dimmable exterior mirrors, VCDS
Previous : Chevrolet Blazer 2001 LT 4.3 petrol
