Old 9th March 2014, 02:35 PM
Default Torque converter clutch stuck.
I've been noticing a clunk when engaging drive or reverse. This clunk is usually preceded by a slight pause then clunk. I did a scan with VCDS and it is showing the torque converter clutch is stuck in the off position. It started doing this a couple of months ago so I had the fluid changed and cleared the codes but it made no real difference. The clunk is still there and the same fault code has come back. Is there a way of unsticking the clutch without the need for a transmission stripdown? If I go to any specialist in Dubai as sure as God made little apples they will recommend a complete rebuild.
Steve
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition.
Old 9th March 2014, 02:37 PM
By the way, I am assuming that this clunk is due to the converter clutch being stuck. If they are two separate problems, what are they?
Old 10th March 2014, 12:16 PM
RRPhil RRPhil is offline
The torque converter is a welded assembly and the lock-up clutch is captive inside this welded assembly.
LUC piston shown in green, friction plate in red
Piston
Friction plate
The torque converter can be replaced without opening up the transmission but the transmission assembly has to be removed from the vehicle to provide access. The torque converter simply slides off its splines and no specialist transmission knowledge is required to replace it – any competent mechanic should be able to manage it. The only tricky bit is ensuring that the oil pump drive dogs are engaged when it is replaced.
The lock-up clutch is fully engaged in the higher gears only to reduce the slip across the torque converter (to save fuel). It is not engaged in 1st or Reverse so I can’t see why it would contribute to a clunk on gear selection.
The LUC is either fully on (locked solid), off (disengaged) or in its ‘continuous slip’ mode (approximately 3% slip) which is used to eliminate torsional vibration at lower engine speeds as ZF decided not to fit a damper to the Sachs W260/280S-2GWK unit to save weight/space.
Phil
Old 10th March 2014, 12:27 PM
Huge thanks Phil from me for all your sharing of knowledge and input to our forum, I'm sure I will try to make many of your replies stickies where appropriate Cheers Neil
Old 12th March 2014, 04:15 AM
Thanks Phil. Very useful information. So, it's not the LUC causing the clunk. Any ideas what it could be?
