Old 15th March 2014, 07:24 PM
nickid's Avatar
nickid nickid is offline
Default nightmare day
Decided to clean the throttle body today and when removing it, the bit tool i was using fell into the bell housing.
What's the best way to get it out????
this is where I think it went in, and I can now see a silver score mark where the bit must be rubbing off the rust.
Old 15th March 2014, 08:23 PM
get one of those flexible arm magnets and poke around till it sticks on the end, but without seeing the hole it fell into thats just a best guess
Old 15th March 2014, 09:47 PM
nickid's Avatar
It's either bouncing or stuck next to something that is moving.
Old 23rd April 2014, 06:00 AM
Nollywood's Avatar
Pull the transmission, if a flexi magnet won't reach it. If it catches the torque converter at 3,000 rpm, it'll be sent through the casing.
I had the same with a 10mm nut in an Audi 100. Smashed a hole through the transmission.
Old 23rd April 2014, 06:30 AM
nickid's Avatar
It's been bouncing about for a while and by the sound of it, there isn't much left of the bit left
