Old 27th March 2014, 06:59 PM
brabus brabus is offline
Default White smoke on tickover
Evening, just after some views on the below.
Test drove an A8 last week 4.2 petrol lpg d3, on tickover after a test drive engine at normal operating temperature there was white smoke coming out of both exhausts. Would this be cause for concern? could this be related to the lpg system?
Old 27th March 2014, 07:44 PM
Pretty sure mine took quite a while to stop the white smoke, no LPG and didn't lose coolant, so could just be the exhausts taking a long time to get up to temperature.
Old 28th March 2014, 07:47 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Has it been stood up for a while?
It could be condensation or water in the exhaust pipes burning off.
was the smoke constant amount?
How was the coolant level?
[center]
06 3.0TDI Quattro:
Options:
Old 28th March 2014, 07:49 AM
Dave McB Dave McB is offline
more than likely condensation in the exhaust on start up.
Also bear in mind that on start up the engine will run rich until up to operating temps (ie the choke is on)
Old 28th March 2014, 06:48 PM
The vehicle had already been driven upto operating temperature (on an A road) , stopped for about 15 minutes then driven for about 5 minutes. The smoke was a constant amount, didnt get any worse and the coolant hadnt moved.
