Old 29th March 2014, 07:03 PM
Palmer Palmer is offline
Default DPF and Cat removal
Am i right in thinking removal will trigger limp mode unless the dpf is taken out the system electronically??
Old 29th March 2014, 07:06 PM
Yep and it'll potentially fail the mot visual inspection too
Old 31st March 2014, 12:23 PM
Depending on how it's done, it may fail the MOT test.. Any decent remover will cut out from the top of the container and take the DPF itself out and weld back together to keep it as hidden as possible.
Old 31st March 2014, 12:55 PM
The DPF on the 3.0 is a double unit that includes a small catalyst to create regeneration heat prior to the filter. The whole lot can be crumbled out by ramming a crowbar or stake in one end. Very messy job though and wear a mask. Then the casing is intact. Just need to uninstall DPF.EXE from the ECU out by a chip tuner such as Shark.
Old 31st March 2014, 01:08 PM
Just a shame they can't install NOSMOKE.COM when they do it..
It's also not much more to get a remap done while you're at it as the labour costs are identical.
