Old 31st March 2014, 11:27 AM
Dan Dan is offline
Default Vag-com/vcds
So, to enable video in motion, I have found these links:-
http://trick77.com/2009/07/18/enable...s-vag-com-mmi/
http://trick77.com/tools/mmi3g_vimcode.php
Has anyone tried this? And does anyone have a VAG-COM/VCDS to use / rent / borrow?
Also, need the serial number from the head unit to generate the login code. But which bit of the 3G system is classified as the "head unit"!?
Old 31st March 2014, 11:37 AM
Ive got VAG com in Swindon if you can make it over this way
Old 31st March 2014, 11:42 AM
Dan Dan is offline
Swindon is only 40 mins, you're a star, thanks!
Old 31st March 2014, 12:00 PM
any evening is normally ok just let me know what suits
Old 31st March 2014, 12:09 PM
Dan Dan is offline
ok cool, will try to find out the serial number of the "head unit" and let you know.
Thanks again.
Old 1st April 2014, 07:14 AM
mannyo mannyo is offline
Dan
The serial number can be obtained using VCDS and scanning module 7 - Control Head so you don't need to dig it out yourself.
Manny
Past
Old 1st April 2014, 08:52 AM
Dan Dan is offline
Thanks Manny -
On a previous forum I eventually became fairly knowledgable about the car, and I look forward to the time I can be useful to other A8 newbies! Was just about to order some removal keys too
