Old 3rd April 2014, 08:25 PM
Question HELP with Mrs Golf needed, please
Hi everyone.
As per title, I'd like to ask for your help/guidance as unfortunately I am not a very good mechanic. I understand what the errors are about (more less), but thats about it. I'm able to replace lambda sensor, solve the misfire and locate EGR, but understanding of how they relate to each other in case one of them fails is pretty equal to 0
VW Golf IV 1.4 petrol
Address 01: Engine Labels: 036-906-032-AXP.lbl
Part No: 036 906 032 L
Component: ME7.5.10 3869
Coding: 00031
Shop #: WSC 00117
VCID: 193922F183164CD67C9-5140
WVWZZZ1JZ2P272855 VWZ7Z0A4403030
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
P1196 - 35-10 - Electrical Malfunction - Intermittent
16785 - EGR System
P0401 - 35-00 - Insufficient Flow
Readiness: 0000 0000
My first and only one for now question is: Could a misfire on a cylinder 1 possibly cause other two errors to come on, lambda and EGR, or could wrong reading on lambda sensor make EGR to not work properly and cause misfire, and finally, or could EGR cause a misfire on a cylinder 1 and lambda sensor to fail/read incorrect values????
Any input before I start digging will be VERY much appreciated
I haven't driven the car yet, but engine is just doesn't sound right. I've asked Mrs if car has less power or if she noticed any difference since the light came on the dashboard, and she said not really !!!! Really??? Don't take me wrong, but if I would remove the windscreen completely and ask if she can feel/notice any difference, the answer would be probably: Not really
And on that note I'd like to Thank You ALL for your time and any input.
Old 4th April 2014, 04:01 PM
Come on guys...I know it hasn't got 4 rings BUT I know you know the answer to it, or at least have some advice.
I don't trust many people, especially when 3 vw forums says one thing and one something different and thats when I'm lost as this sort of mechanical repairs are not my thing, but I trust your expertise guys very much
So don't be shine, know one will dislike you for helping to a VW owner
Old 4th April 2014, 05:41 PM
Lambda sensor fault is not critical, it's just for the heater so it will take longer for lambda to start working on cold starts say 2 minutes instead of 20 secs.
The first to look at is cylinder 1 misfire and it can be causing multiple cylinder misfires. Check spark plug, ignition coil, injector and wiring for cylinder 1.
Old 4th April 2014, 08:33 PM
....aaaaaaand we finally broke the ice
Cheers ainarssems, I appreciate it
I will play with it tomorrow.
Changing lambda sensor shouldn't be a problem anyway.
Year ago I did a full service on it inc. spark plugs inc all the wires for it and stuff such as new discs and pads, clutch, engine and gearbox oil/filter, water pump, alternator belt, cambelt, thermostat, all fluids all round and on and on and on.
Everything was fine till this week.
How about EGR, could this fault be related to misfire???
What shall I look for when checking injectors and other bits?? I know this may sound silly but I'm just not good in the engine area, sorry.
Thanks once again
Old 5th April 2014, 07:39 AM
Start with checking all the plugs, make sure they are correctly and fully plugged, check for water ingress/corrosion. Check wires for visual damage. Then move to swapping parts between cylinders-spark plugs, coils, injector one at the time and see if cylinder 1 misfire moves to another cylinder together with the part.
Old 5th April 2014, 08:05 AM
Has the car been serviced regularly? Had a fuel filter recently? Not gad bad furl put in it etc?
Old 5th April 2014, 02:18 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I'd check the coil packs.
Swap them over and see if the error for the miss fire comes back on another cylinder.
EGR could just need a clean.
[center]
06 3.0TDI Quattro:
Options:
Old 5th April 2014, 03:58 PM
Guys, THANK YOU to all of you
Unfortunately I'm still laying in the bed and can't move because of the cold I got two days ago. Will jump on it probably on Monday.
Del, I simply don't know. When Mrs passed her driving license year ago I promised to her I give her a 1k for some basic car so she can get use to driving. Idea was to get some destruction derby style car so I wont get heart attack each time she scratch it. It was a right decision as in first few months she already tried to move couple of walls in local car park.
I told her to buy a German car but not with a high mileage, and she came back home with a 1.4 petrol Golf with 150k on the clock, first car she viewed
Thats why straight away I replace almost everything from clutch to all the belts, brakes etc.
As she still hasn't finished her PA courses, she decided to keep it for another year,, but car is close to its end.
One thing I haven't replaced is the mentioned EGR, plugs, coils and all the wiring has been replaced. Plus I treated car with a Terraclean and told her to keep filling up with Vpower not some cheap petrol.
Anyway, I will follow your advice guys as soon I get better, Thank You once again
And will update you as soon I find the problem.
Old 6th April 2014, 10:41 PM
Oh man, I just re read my post, keyboards and beer should never be mixed.
You could donate the 8 to the wife and by that black s8 that roberto posted
Old 7th April 2014, 04:03 PM
I already tried few times but, one, she is scared as hell to drive it, too big (she says that about other ''stuff'' as well ), two, I wouldn't be able do it, I want to live a long life not to have 12 heart attacks before hitting 50 as she would scratch wheels, doors, bumpers and good knows what else on monthly basis, three, we will be buying house in couple of years, plus we already have 1000s of pounds planned on all sort of entertainments/holidays/stuff and she will need new (much better) car this year as well, soooo I may have to stick with my 8 for some time now.
It's a well looked after car, I'm looking after it as well plus it cost me so much money each year (last year upgrades plus running cost just under £11.5k)
It would be a great financial loss selling it or donating in current circumstances and plans ahead.
And for money she plans to spend on next car I would buy and decent 8 if she would adopt mine.
Anyway, will update you guys as soon I get round her Golf.
BTW, I read your post couple of times but I got it.
Not gad bad furl put in it etc? translates to Not had bad fuel put in it etc?
