Old 20th April 2014, 03:31 PM
Sir WIll Sir WIll is offline
Default VAGCOM Connection Problems on D3
I connected VAGCOM earlier on the D3, connected and could read the engine and codes (No Faults).
But I could not connect to any other module? Any thoughts?
Old 20th April 2014, 03:41 PM
You need VCDS with a proper cable that supports the later interfaces.
I've got an older (paid for, registered) version (probably similar to yours) and it's fine for my D2 but will only read the engine on a D3.
As I sadly found out the other day when I offered help to a D3 owner here.
If you have a registered copy of VAGCOM you might get a discount from RossTech on the upgrade, otherwise it's start again. http://store.ross-tech.com/shop/cat/IntUp.html
Old 20th April 2014, 03:46 PM
Ah yes looks like you need a HEX+CAN interface.
eBay have some options:
http://www.ebay.co.uk/itm/1113313543...84.m1423.l2649
Old 20th April 2014, 03:51 PM
Did you reset vagcom since you changed vehicle? Maybe it needs to 'acquire' the D3 as a new car correctly on your laptop?
I have a full registered VCDS hex/can/USB cable here in Swindon if you can get over this way
Old 21st April 2014, 09:44 AM
You need the CAN interface to get to the other bits of the D3.
Old 28th April 2014, 07:32 PM
Thank you for the offer Architex mA8tey much appreciated.
I have ordered a Hex Can Cable and a second hand IBM Thinkpad so should be up and running in a couple of days.
