Old 27th April 2014, 07:27 PM
Bisonhead Bisonhead is offline
Default MMI Screen Gear Wheels...Again!
Sorry for dragging this up again, I know you will be sick to death of posting the same old links!!
I have successfully taken out the MMI unit and will be stripping the motor out to get access to the gear wheels.
My questions is, if only one wheel needs replacing, can I simply replace that one. Also, where is the best place to get a replacement? My first thought was a scrappy but you lot are the knowledge!
Cost is an issue unfortunately so no sending the entire unit to the US for repair or any other crazy £400 fixes!
Thanks!
D3 A8L 4.2 Quattro
Old 27th April 2014, 08:07 PM
audifin audifin is offline
Have you seen this? http://www.ebay.co.uk/itm/Audi-A8-MM...item3a8a00fa0c
Old 28th April 2014, 10:43 AM
Originally Posted by audifin View Post
I have now, thank you.
£54 seems much more reasonable.
D3 A8L 4.2 Quattro
Old 30th April 2014, 09:31 PM
You can get brass replacemens that last longer .. when you rebuild use grease and they will run nice and ssmooth
Old 30th April 2014, 09:32 PM
Sorry didnt see the link �� .. yes they are the ones
Old 30th April 2014, 10:27 PM
Conquistador's Avatar
Have a look at this...
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 3rd May 2014, 10:44 AM
Fantastic, helped me with the last hurdle when getting the zeger clip and gear axis off...although I broke the zeger clip
Thanks for this!
D3 A8L 4.2 Quattro
