Old 9th May 2014, 07:47 AM
Default Flickering handbrake light
When my car was serviced they told me that the handbrake warning light wasn't working. Not an MOT issue and everything was working fine so just a report.
Investigating further I found that it actually flickers on a bit while moving the handbrake lever, but is definitely off at other times, so I suspect a loose or failing microswitch.
Does anyone know where the switch is and how easy it is to swap?
