Old 22nd January 2009, 08:54 PM
A8 Doc A8 Doc is offline
Default Removing the 155mph speed limiter
First of all you will require a serial based VAGCOM compatible cable. I say compatible as we do not require VAGCOM for this operation so feel free to use an Ebay rip off. I do not condone using this for VAGCOM, the software and cable are a bargain so please support the manufacturer.
Download Lemmiwinks from Here!!
1) Click READ under ECU
2) Adjust speed limiter on Channel 7 in increments of 1mph.
3) Click SET under ECU
Altering ANY of the channels without tuning knowledge is at your own risk!!
All done! Go find an autobahn
