Old 19th May 2014, 04:32 PM
Oli18's Avatar
Oli18 Oli18 is offline
Default My list of Fault Codes
Hi all,
Having been inspired by others recently posting their fault codes and now my house renovation is coming to a close, I thought i'd start tackling some of the fault codes on my 8.
I have cleared the codes and driven the car for about 30 mins. The list below is therefor a 'fresh' list of codes.
Would really appreciate your inputs into the list.
The following are ones i'm ok to live without addressing:
- Driver's door touch sensor (let's face, so many just have a mind of their own - not working half the time only to come to life again )
- TPMS - I have the control module but don't see it as a priority to buy 5 new sensors
- EPB - it works 99% of the time...once a month i just have to use it a few times to clear the dash light which i know many others do also.
Thanks,
Oli
VCDS Version: Release 12.12.2
Data version: 20140212
Monday,19,May,2014,17:11:14:17815
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 18 19 1D 1E 25
34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
VIN: WAUZZZ4E26N019357 Mileage: 185800km/115450miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Not registered 0001
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4E1 910 409 A HW: 4E1 907 409
Component: 4.2L V8TDI A000AGMª0070
Revision: --H01--- Serial number: AUX3Z0F0383869
Coding: 0011773
Shop #: WSC 00759 210 86480
VCID: 2241C55DFD8A660EAD3-8077
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 P HW: 09E 927 156 B
Component: AG6 09E 4,2lTDI RdW 0030
Revision: --H01--- Serial number: 0076831
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 30653F15A366C49E2B7-8065
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F0383869
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: D8B527B56B567CDE037-808D
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
5 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 101
Mileage: 175808 km
Time Indication: 0
Date: 2013.09.23
Time: 06:58:02
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 14
Reset counter: 88
Mileage: 175808 km
Time Indication: 0
Date: 2013.09.24
Time: 11:16:08
01176 - Key
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 255
Mileage: 182144 km
Time Indication: 0
Date: 2014.01.31
Time: 11:51:10
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 6
Reset counter: 61
Mileage: 184064 km
Time Indication: 0
Date: 2014.03.16
Time: 10:40:58
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 12
Reset counter: 100
Mileage: 184432 km
Time Indication: 0
Date: 2014.04.27
Time: 16:06:26
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 244DC345E79E683EDFF-8071
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300AC067562505
Coding: 0000002
Shop #: WSC 00759 210 68801
VCID: 3A711D3D751A0ECE953-806F
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 318HI037505510
Subsystem 3 - Serial number: 7429.08.030000000000010000ÿ
Subsystem 4 - Serial number: 010000ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000088042
Coding: 0022561
VCID: 1C3DFBA5DFEE50FE67F-8049
1 Fault Found:
00819 - High Pressure Sensor (G65)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 83
Mileage: 183479 km
Time Indication: 0
Date: 2014.03.05
Time: 06:36:17
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0133121
VCID: 3669090D4102EAAE71B-8063
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8049216
Shop #: WSC 00000 000 00000
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI A000AGSª0070
Coding: 0011773
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0011154
VCID: 254BDE41ECA49136C81-8070
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Mileage: 185800 km
Time Indication: 0
Date: 2014.05.19
Time: 07:40:00
Freeze Frame:
Temperature: 26.0°C
Voltage: 9.09 V
Bin. Bits: 00000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H12 3610
Revision: 91H12360 Serial number: 0037P000DLH0
Coding: 0431707
VCID: 2757D44996A88326FAD-8072
Subsystem 1 - Serial number: 63328RB400E24D6EV
Subsystem 2 - Serial number: 63428RB400E2571CK
Subsystem 3 - Serial number: 63528RB400E2571DM
Subsystem 4 - Serial number: 63628RB400E256F4R
Subsystem 5 - Serial number: 63729RB400D364F8W
Subsystem 6 - Serial number: 63829RB400D364A8S
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 177172 km
Time Indication: 0
Date: 2013.10.13
Time: 00:00:08
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112151
VCID: E5CB1E412C24D136881-80B0
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 980 N HW: 4E0 920 980 N
Component: KOMBIINSTR. VDO H70 0410
Revision: D02 Serial number: AUDID3F0000091
Coding: 0000403
Shop #: WSC 00759 067 57207
VCID: 3261351DAD6AF68E5D3-8067
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 60685 km
Time Indication: 0
Date: 2008.10.08
Time: 08:32:47
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 F
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000001
VCID: 1A31FDBDD5DA2ECE753-804F
2 Faults Found:
01412 - Glow-Plug with Flame Monitoring (Q8)
02251 - Heater Unit Locked
000 - -
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 F
Component: Gateway H11 0090
Revision: 11 Serial number: 19004061088029
Coding: FEFFFBDF2B7504
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 61
Mileage: 175805 km
Time Indication: 0
Date: 2013.09.01
Time: 16:38:45
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Reset counter: 61
Mileage: 175805 km
Time Indication: 0
Date: 2013.09.01
Time: 16:38:45
00467 - TV Tuner (R78)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 92
Mileage: 184441 km
Time Indication: 0
Date: 2014.04.27
Time: 16:07:10
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2 905 218
Component: FPI_1 H06 0060
Revision: 06000106 Serial number: 11082004063652
Shop #: WSC 00048 210 176595
VCID: DEB931AD097282EE49B-808B
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 0
Reset counter: 170
Mileage: 175792 km
Time Indication: 0
Date: 2013.09.01
Time: 16:41:28
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
VCID: 2B5F28794A40A7461E5-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV 1940
4E0905852E ELV 1940
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 101
Mileage: 175808 km
Time Indication: 0
Date: 2013.09.23
Time: 06:58:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 88
Mileage: 175808 km
Time Indication: 0
Date: 2013.09.24
Time: 11:16:08
01176 - Key
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 255
Mileage: 182144 km
Time Indication: 0
Date: 2014.01.31
Time: 11:51:10
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 61
Mileage: 184064 km
Time Indication: 0
Date: 2014.03.16
Time: 10:40:58
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 12
Reset counter: 100
Mileage: 184432 km
Time Indication: 0
Date: 2014.04.27
Time: 16:06:26
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A512D7D85BABE4EE53-807F
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 92
Mileage: 177332 km
Time Indication: 0
Date: 2013.10.21
Time: 21:55:34
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 96
Mileage: 185780 km
Time Indication: 0
Date: 2014.05.16
Time: 15:24:48
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H47 1060
Revision: 00000000 Serial number: 364AS067525548
VCID: 3B7F18397A2037C68E5-806E
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 84
Mileage: 185475 km
Time Indication: 0
Date: 2014.05.04
Time: 13:56:34
Freeze Frame:
Hex Value: 0x5366
Hex Value: 0x4712
Hex Value: 0x1A00
Hex Value: 0x6AC4
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H03 0090
Serial number: 00000534600055
Coding: 0036036
VCID: 1D3BF6A1C4F459F6901-8048
5 Faults Found:
02139 - Control Circuit for Left Front Interior Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 198
Mileage: 177656 km
Time Indication: 0
Date: 2013.10.30
Time: 19:50:00
01370 - Alarm triggered by Interior Monitoring
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 76
Mileage: 0 km
Time Indication: 0
Date: 2014.04.28
Time: 09:59:00
Freeze Frame:
Bin. Bits: 00000001
02138 - Control Circuit for Front Right Interior Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 56
Mileage: 177656 km
Time Indication: 0
Date: 2013.10.30
Time: 19:02:00
00211 - Control Circuit for Rear Illumination Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 52
Mileage: 177656 km
Time Indication: 0
Date: 2013.10.30
Time: 19:20:00
00215 - Control Circuit for Reading Lights Rear Right
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 198
Mileage: 177656 km
Time Indication: 0
Date: 2013.10.30
Time: 19:22:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032622
VCID: 2045CF55F386741EBB7-8075
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601170155
Coding: 0004349
VCID: 2855D7759BB68C5EF37-807D
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 89
Mileage: 185654 km
Time Indication: 0
Date: 2014.05.08
Time: 17:57:39
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 D HW: 4E0 035 466
Component: BO_D3 H06 0320
Revision: 11S00002 Serial number: 00504060002262
Coding: 0000023
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 01901060000773
Subsystem 3 - Serial number: 0219.01.060000000100030013ÿ
Subsystem 4 - Serial number: 030013ÿ
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000078312
Coding: 0010101
VCID: 1E39F1ADC9F242EE89B-804B
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032622
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0001031
VCID: 1F47CCA9CEF84BE682D-804A
1 Fault Found:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 1
Fault Frequency: 9
Reset counter: 99
Mileage: 178392 km
Time Indication: 0
Date: 2013.11.30
Time: 16:10:59
Freeze Frame:
Voltage: 12.32 V
Count: 93
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000006
VCID: 3D7B1621643439F6B01-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 304AS067613997
Coding: 0000001
VCID: 31633A11A86CCD96249-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 A HW: 4E0 919 148
Component: R0078 TVhybridTuner 0280
Revision: R0H05000 Serial number: 76300700425102
Coding: 0000003
VCID: 2143CA51F88C7D16B49-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010029
Shop #: WSC 00759 210 61239
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2601300067
Coding: 344530393135313035412056413032363031333030303637
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 19
Reset counter: 255
Mileage: 175823 km
Time Indication: 0
Date: 2013.09.24
Time: 11:36:10
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 177211 km
Time Indication: 0
Date: 2013.10.19
Time: 02:38:35
00992 - Consumption Cut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 177153 km
Time Indication: 0
Date: 2013.10.10
Time: 15:29:14
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 255
Time Indication: 0
Date: 2013.10.19
Time: 02:07:13
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 181013 km
Time Indication: 0
Date: 2014.01.20
Time: 08:11:01
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032622
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000601130467
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032622
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720602003606
Coding: 0301008
VCID: 234FC059E2906F06A65-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007608675
Coding: 0010900
VCID: 2C5D2B658F4EA07E17F-8079
End ---------------------------------------------------------------------
Audi A8/S8 D2 Flickr Group
