Old 20th May 2014, 10:10 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Audi MMI2G Bluetooth retrofit kit
On behalf of a friend.
I assume it will work on a A8?
Audi MMI2G Bluetooth retrofit kit, genuine Audi module and comes with the microphone and BT antenna, the wiring harness is aftermarket but it works fine. I've only removed it from my A6 Avant to fund my 3G upgrade.
Please note this will NOT work on the RNS-E systems.
£180. Posted Special delivery.
[center]
06 3.0TDI Quattro:
Options:
Old 20th May 2014, 10:38 AM
Or if you have the crappy Motorola unit, that's a 30 minute swap job...
Old 21st May 2014, 01:40 PM
ScottD3's Avatar
Just bolt this unit in its place?
[center]
06 3.0TDI Quattro:
Options:
Old 21st May 2014, 01:51 PM
Pretty much... Fits in the same hole under the passenger carpet, some connections to be swapped from the motorola connector to the new one. All the details are on the thread below. Worst case, you may need to buy the little connector block
http://forum.a8parts.co.uk/showthread.php?t=908
Old 3rd June 2014, 08:11 AM
ScottD3's Avatar
Sold!!
[center]
06 3.0TDI Quattro:
Options:
