Hi all
Now can anyone help with this one , i was checking over the car yesterday as was having a prob with cold start and bounching revs. found a crack in one of the rubber conection tubes from the Fuel pressure regulator valve which I have fixed, But on checking the vac system noticed that on the passager side the vac pipe that would connect to the blue vacuum reservoir was not connected to anything. I looked and looked but could not find the Vacuum reservoir for that side would anyone have a pic of the location on the car mine is a d2 3.7 QS. Thanks all for the help Steve ![]() |
Same car as mine and I'd love to help.
Don't recall seeing blue vacuum reservoirs. Are these at the front of the engine ?
2002 3.7 quattro sport (SOLD) |
A fellow 3.7Qs.
There behind the front wings so not visable from the engine bay but Part of the vauume system I belive |
It would be the weekend before I can get to this.
The liner isn't that difficult to remove
All done liner removed and found that the blue vacuum reservoir was not conected......i dont think it as been since i have had it.....all fixed and conected now, and the vac system work...with the bellows retracting on start up as they should....will give it a litte test run and see how she drives.
![]() All done just before the rain |
