Go Back   A8 Parts Forum > General Natter > Owners Meets
Owners Meets Any info for any meetings, events, track days
Old 23rd July 2014, 08:14 PM
Default Meet aftermath no 2!
At the Raffle on the Saturday night I won a USB stick that was suppose to have ELSAWIN and ECTA on but all it has is something called VMware or something like that. Am I missing something?
CtL
Old 23rd July 2014, 08:18 PM
Yes. VMware is a virtual computer. The other stuff is probably inside it - you need some instructions from whoever put it together.
In contrast I won a bottle of Royal Salute whisky - no instructions required.
Old 23rd July 2014, 10:17 PM
I would expect vmware to be the virtual machine software, which you can then install on a windows 7 or 8 pc and if it's been fully configured with the software you need it may well be there too. Depends how big the files are? Etka and Elsawin are HUGE! 30GB for Etka alone, 48GB for Elsawin
Old 24th July 2014, 05:29 AM
johnny_quattro's Avatar
Default VMWare
The VMWare application is tiny in comparison to ElsaWin. Not sure about ETKA as I don't know what that is but I've seen it mentioned numerous times and normally in Adrian's posts.
I suspect you may have the VMWare installation package as an executable setup file or similar, and the ElsaWin/ETKA may be on what's called a .VDI (virtual disk image) file. If it's been done properly, then the VDI will comprise a computer operating system such as Windows XP/7 etc. with ElsaWin already installed.
You would install VMWare, attach the .vdi file and then 'boot' the OS from within your current OS. I've done something similar in the past for HPsauce. Feel free to send me a msg if you get stuck - I'll even talk you through it over the 'phone if need be.
Old 24th July 2014, 05:33 AM
30GB for Etka
Mine is only 7.6GB with VW, Audi, Sea, Skoda and VW commercial vehicle data, only missing Lamborghini and Bentley.
Elsa can take a lot of space depending which brand data you load, Audi only is 17GB
Old 24th July 2014, 06:34 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
How big is the stick and how big is the data on it?
It could be the VM where you just run it and it has Windows XP installed with ELSA and ETKA installed.
so you can run from any machine.
[center]
06 3.0TDI Quattro:
Options:
Old 24th July 2014, 07:17 AM
mannyo mannyo is offline
Generally the process would be
Install vmware onto your own computer, copy the entire contents of the memory stick to a new folder on your laptop/pc
Open vmware player and then import the contents of that folder, then press the play button.
Another copy of windows will load within a program window which has etka and elsawin already installed.
Manny
Past
Old 24th July 2014, 07:25 AM
Hi Mike, The stick was donated by Richard (PsYChE) who can, no doubt, provide full instructions. I suggest you PM him.
Old 24th July 2014, 08:38 AM
Although he is currently on holiday....think he might get back this weekend.
Old 24th July 2014, 07:17 PM
Cheers all,
ScottB5 has been in touch and he's local to me so hopefully it will get sorted.
CtL
