Old 5th August 2014, 07:58 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Thumbs up Check Your Kickdown Switch
Found out my kick down switch was in the off position.
Not sure why but turned it back on it and BOOM kickdown, also no more fuel.
It appears the D2 facelift lads had their kick down switches turned off as well.
http://forum.a8parts.co.uk/showthread.php?t=50
Why would someone turn this off?
[center]
06 3.0TDI Quattro:
Options:
Old 5th August 2014, 06:48 PM
With the D2, you installed the kickdown switch by rotating it in the same direction as you do to disable the switch. I always guessed it was from factory that it was off as either someone was supposed to turn it back a notch during manufacture, or at least the PDI but was rarely done.....
It is a nice boost when you enable it after finding its been off sicne you got it...
Old 5th August 2014, 07:15 PM
audifin audifin is offline
Wow.. what a top tip! Mine was switched off, I had no idea
Old 6th August 2014, 07:37 AM
ScottD3's Avatar
For years most of these cars has had no kickdown.
Madness!!
[center]
06 3.0TDI Quattro:
Options:
Old 6th August 2014, 09:37 AM
Hi Ian - to clarify/check, on the D2, it's a turn and click to the right to enable kick down, but presumably a turn and click to the left to disable, or have I missed a trick here when it comes to the directionality of the switch?
Old 6th August 2014, 09:38 AM
No click, just turn it.
When it's in the right (right) position it will click when pressed.
Old 7th August 2014, 07:37 AM
Lyons Lyons is offline
D3 the same process I assume? How much does it turn each way?
Old 7th August 2014, 07:51 AM
ScottD3's Avatar
Yup same.
Not much, couple of MM
[center]
06 3.0TDI Quattro:
Options:
Old 7th August 2014, 10:03 AM
LordHefner LordHefner is offline
Yup same.
I get the idea of it being switchable, however find it strange that it's default is in the off position over on. Mine is off with the Main Stealers again today so won't be ale to check mine until tonight
In the D2 link that you posted on post 1, I read through and there was instructions for testing it off whilst parked and engine off, is that something for just the D2 owners or would this work for the D3 as well?
Regards, Mark.
Registration: 2 WXG (Private plate from 1962
Model: MY 2008 08 3.0TDI Quattro Sport, Black on Black (Transporter Edition) Lowered 60mm on drop link bars. Alloys swapped out to RS6 style 20" x 9.5". It's got full tints on all windows, and has the black leather interior. Remapped by Elite Automotive in Cornwall, giving an increase output to 290bhp/450lbs.
Options: Keyless Entry & Start, Bluetooth Hands Free, Quad Zone Climate, 3 Spoke Sports Tiptronic Multi Function Steering Wheel, Black Leather Comfort Seats, AMI, Drivers & Passenger Electric Memory Seats, Auto Dimming Mirrors, Bi-Xenons.
Future Plans:
Selling my current Audi A8 Quattro Sport and replace is with a newer D4 Audi A8L with the 4.2V8 Twin Turbo setup once again it must be black. I'm looking for one with the options added where it has the rear recliing seats, with heated outers. Bose speakers minimum and B&O's if affordable. Rear and back door sun blinds prefered.
Planned Mods:
Upon the arrival of my A8L D4, I will be once again having the ECU remapped to a performance setting over economy. Rear Tints as dark as can go whilst also tinting the front windows with a medium tint. Once again I will be purchasing lowering links for the air ride suspension and setting it at 55mm lower when in comfort as my desire rideheight over standard. Alloys will be 21" however the one current most likly to be the next car already has a brand new set of 2016 S8Plus wheels on it.
My Business: "The Transporter - Cornwall" find us on Facebook or download the Smart phone application by clicking the link below. http://TheTransporter.appsme.com
Old 7th August 2014, 10:10 AM
ScottD3's Avatar
No idea if it will work with the D3s.
I just get on the A38, go up to top gear and plant my foot. lol
[center]
06 3.0TDI Quattro:
Options:
