Old 22nd August 2014, 09:18 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Flat Battery and Staying at 10%
Monday was the first time I drove the car for almost a week, there was no issues with starting and no errors apart from brake pad warning lights.
Thats random at the moment.
Drove the car monday, left it till tuesday, drove it again and not touched it till wednesday when Lordhefner came over to look at his lights.
Looking at the cars I noticed the battery was slightly flat.
I went to start the car and just started.
I left it idling and monitored the battery level slowly climb.
I turned the car off when it was at about 60-70%.
Left the car till this morning and it went flat. No error, no lights, just a handfull of clicking.
Jump started the car and went off to work. I took the long way to work which is about 30 minutes drive.
Got in work and the battery monitor still displayed 10%.
Got VCDs out and did a scan.
Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number: AUX3Z0F0383242
Coding: 0011973
Shop #: WSC 00481 210 97430
VCID: 295FC0D28095EB56EC9-807C
4 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 257110 km
Time Indication: 0
Date: 2014.07.25
Time: 14:09:09
Freeze Frame:
RPM: 819 /min
Torque: 124.8 Nm
Speed: 2.2 km/h
Duty Cycle: 1.0 %
Voltage: 13.22 V
Duty Cycle: 23.3 %
Temperature: 26.1°C
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 257207 km
Time Indication: 0
Date: 2014.08.01
Time: 08:56:52
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 11.78 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 20.5 %
005481 - Cruise Control Switch (E45)
P1569 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 126 /min
Torque: 249.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 6.54 V
Bin. Bits: 00001111
Torque: 249.6 Nm
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 10.41 V
Bin. Bits: 00101111
Torque: 89.7 Nm
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 A HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0100
Revision: --H01--- Serial number: 4131730
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 214FD8F2F8A52316B49-8074
1 Fault Found:
049478 - No Communication with Diagnostic Gateway
U0146 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 257786 km
Time Indication: 0
Date: 2014.08.22
Time: 00:07:17
Freeze Frame:
RPM: 32 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 16.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 224DD7FEFDA3380EAD3-8077
6 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
02083 - Message for Delay Request
01299 - Diagnostic Interface for Data Bus (J533)
01315 - Transmission Control Module
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F0383242
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: D8B935166B7F22DE037-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 225
Mileage: 257168 km
Time Indication: 0
Date: 2014.07.30
Time: 12:54:02
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 257488 km
Time Indication: 0
Date: 2014.08.14
Time: 12:59:20
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 300AE067562147
Coding: 0000002
VCID: 2E5533CEB97B8C6E39B-807B
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 318AG067517122
Subsystem 3 - Serial number: 7410.01.0600000000218B0281˙
Subsystem 4 - Serial number: 8B0281˙
1 Fault Found:
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 16
Mileage: 257220 km
Time Indication: 0
Date: 2014.08.04
Time: 08:21:28
Address 08: Auto HVAC Labels: User\TEST-08.lbl
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000083962
Coding: 0084051
VCID: 1C31E906DFC70EFE67F-8049
3 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 101
Reset counter: 7
Mileage: 257105 km
Time Indication: 0
Date: 2014.07.24
Time: 17:13:18
Freeze Frame:
Voltage: 13.40 V
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 42
Mileage: 257151 km
Time Indication: 0
Date: 2014.07.30
Time: 06:32:23
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 152
Reset counter: 42
Mileage: 257151 km
Time Indication: 0
Date: 2014.07.30
Time: 06:33:33
Freeze Frame:
Voltage: 13.50 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143121
VCID: 36651BAE412BB4AE71B-8063
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
3 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 46
Mileage: 257779 km
Time Indication: 0
Date: 2014.08.19
Time: 11:34:09
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 46
Mileage: 257786 km
Time Indication: 0
Date: 2014.08.20
Time: 13:08:16
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 46
Mileage: 0 km
Time Indication: 0
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: E5C70CE22C0D8F36881-80B0
Component: Lenkradmodul H07 0090
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 0 km
Time Indication: 0
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 200030610280C9
Coding: FDFE7FDE3B7504
Shop #: WSC 00583 210 91660
VCID: 275BC6EA9681DD26FAD-8072
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 31
Mileage: 257411 km
Time Indication: 0
Date: 2014.08.10
Time: 11:52:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 257495 km
Time Indication: 0
Date: 2014.08.14
Time: 12:59:17
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 225
Mileage: 257168 km
Time Indication: 0
Date: 2014.07.30
Time: 12:54:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 257488 km
Time Indication: 0
Date: 2014.08.14
Time: 12:59:20
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0010020
VCID: 2859C5D69B9FD25EF37-807D
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 36
Mileage: 257394 km
Time Indication: 0
Date: 2014.08.10
Time: 09:29:55
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 45
Mileage: 257779 km
Time Indication: 0
Date: 2014.08.19
Time: 11:34:16
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H03 0090
Serial number: 00000532900098
Coding: 0036004
VCID: 1D37E402C4DD07F6901-8048
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 46
Mileage: 257492 km
Time Indication: 0
Date: 2014.08.14
Time: 12:59:00
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 45
Mileage: 257776 km
Time Indication: 0
Date: 2014.08.19
Time: 11:34:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032750
VCID: 2049DDF6F3AF2A1EBB7-8075
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 46
Mileage: 257776 km
Time Indication: 0
Date: 2014.08.20
Time: 13:57:56
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601040552
Coding: 0004861
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
2 Faults Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 26
Mileage: 257317 km
Time Indication: 0
Date: 2014.08.06
Time: 16:28:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 46
Mileage: 257495 km
Time Indication: 0
Date: 2014.08.14
Time: 12:59:22
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032750
2 Faults Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 6
Mileage: 257072 km
Time Indication: 0
Date: 2014.07.24
Time: 16:36:56
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 46
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000221
Shop #: WSC 00482 210 98729
VCID: 1F4BDE0ACED115E682D-804A
5 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 257784 km
Time Indication: 0
Date: 2014.08.22
Time: 00:07:17
Freeze Frame:
Voltage: 10.87 V
Count: 247
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 257784 km
Time Indication: 0
Date: 2014.08.22
Time: 00:07:17
Freeze Frame:
Voltage: 10.87 V
Count: 243
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 47
Mileage: 257784 km
Time Indication: 0
Date: 2014.08.22
Time: 00:07:17
Freeze Frame:
Voltage: 10.87 V
Count: 41
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 257784 km
Time Indication: 0
Date: 2014.08.22
Time: 00:07:17
Freeze Frame:
Voltage: 10.87 V
Count: 244
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 257784 km
Time Indication: 0
Date: 2014.08.22
Time: 00:07:17
Freeze Frame:
Voltage: 10.87 V
Count: 241
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
02628 - Sensor for Swivel Module Position; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 257784 km
Time Indication: 0
Date: 2014.08.22
Time: 00:00:00
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009671
Shop #: WSC 00149 210 03776
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1601100625
Coding: 344530393135313035412056413031363031313030363235
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 11
Reset counter: 255
Mileage: 257495 km
Time Indication: 0
Date: 2014.08.15
Time: 07:05:04
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 257503 km
Time Indication: 0
Date: 2014.08.15
Time: 11:06:52
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 257503 km
Time Indication: 0
Date: 2014.08.15
Time: 11:07:02
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 257815 km
Time Indication: 0
Date: 2014.08.22
Time: 08:13:42
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 257786 km
Time Indication: 0
Date: 2014.08.22
Time: 00:06:39
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032750
VCID: 1E35E30EC9DB1CEE89B-804B
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 46
Mileage: 257776 km
Time Indication: 0
Date: 2014.08.20
Time: 13:57:56
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 2441D1E6E7B7363EDFF-8071
1 Fault Found:
02539 - Terminal 30 from Control Module
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 15
Reset counter: 47
Mileage: 257076 km
Time Indication: 0
Date: 2014.07.24
Time: 15:57:00
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032750
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 46
Mileage: 257776 km
Time Indication: 0
Date: 2014.08.20
Time: 13:57:56
End ---------------------------------------------------------------------
All typical flat battery sort of error codes I think.
Cleared the codes, rescan and this is what I got left.
Coding: 0412672
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 8
Mileage: 257808 km
Time Indication: 0
Date: 2014.08.22
Time: 09:15:28
Coding: 0084051
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 8
Mileage: 257815 km
Time Indication: 0
Date: 2014.08.22
Time: 09:03:32
Freeze Frame:
Voltage: 13.70 V
Coding: 0412672
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 8
Mileage: 257808 km
Time Indication: 0
Date: 2014.08.22
Time: 09:15:28
Coding: 0032750
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 8
Mileage: 257808 km
Time Indication: 0
Date: 2014.08.22
Time: 09:03:20
All looking better but no fault codes for the battery. So I guess that's good.
I went in to the battery regulator and checked the battery was set up correctly and it was.
Checked the measuring blocks and its charging at 14.5v, the battery is getting 14.5v volts but battery state is still 10%.
I think the battery is less than 2 years old and hopefully still under warranty if it is the battery.
Anyone got any idea why the battery level and state of charge will stick at 10%?
[center]
06 3.0TDI Quattro:
Options:
