Old 1st September 2014, 05:49 PM
3.7 slp 3.7 slp is offline
Default Easy entry and exit system
Is there a set up for this on the MMI as mine on my2003 A8
does not work the steering wheel does not move in or out for the easy entry and exit. It works fine with the controls on the side of the wheel
I have checked the button on the steering wheel control and does not make any difference. Any tips for me to check
Thanks very much
Steve 👍
Old 1st September 2014, 05:59 PM
It should be linked to the seat memory controls on the drivers door Steve so is the seat memory function switched off at the moment? If it is then switch it back on and set it up against one of the numbers and it should be activated from your key or when you press the relevant number on the memory pad
Old 1st September 2014, 06:17 PM
If you have a VCDS just check if your memory seat module is working fine, I've seen once same problem when that or something similar failed, even if everything worked when adjusting with buttons on the column and seats, but never getting in and out.
Other than that just follows Neil's post, if that wont work then you do need a quick scan.
Old 1st September 2014, 06:50 PM
Thank gents will give that a go. 👍👍
