Old 5th September 2014, 09:29 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default ESP Long Press
Not sure why I did but I did and this where I'm at.
I turned my ESP off, pressed the button for about 10 seconds and the light went off.
That was 2 days ago and I've not driven a car since.
Drove it today and pressed the ESP button to see if the light would came on and it did not.
I have no ESP light on my dash.
What did I just do?
What does this mean?
[center]
06 3.0TDI Quattro:
Options:
Old 5th September 2014, 09:48 AM
Pretty sure it should reset when you restart the car.. Try holding it in for 10 seconds again.
Old 5th September 2014, 09:52 AM
ScottD3's Avatar
Done that nothing.
Can you turn ESP off with you got brake pad warning on?
[center]
06 3.0TDI Quattro:
Options:
Old 5th September 2014, 10:03 AM
Look at ABS on VCDS, maybe it says : ESP button stuck - and you can clear the fault codes.
Old 5th September 2014, 10:05 AM
Is it the brake pad warning, or brake system warning?
Old 5th September 2014, 10:10 AM
ScottD3's Avatar
brake pad warning.
I got a dodgy sensor somewhere.
Looking at that this afternoon.
The pads have less than 10% ware on them, so I know its not them.
[center]
06 3.0TDI Quattro:
Options:
Old 11th September 2014, 03:57 PM
ScottD3's Avatar
The light is back.
WooHoo.
Took a couple of days and hours driving but it's back.
WooHoo
[center]
06 3.0TDI Quattro:
Options:
Old 11th September 2014, 08:14 PM
Hi Scott
Glad it's all sorted now
I also can't stop my self from asking why holding the ESP button for so long??
Old 11th September 2014, 09:12 PM
Lee S Lee S is offline
.....why holding the ESP button for so long??
A single, quick press deactivates the ESP. A 5 second press and hold deactivates the ESP and the ASR (traction control). I have done it a few times, but never had any issues with it coming back on. They recommend turning all those gizmos off when you want a screaming take-off from a standing start. Didn't appear to make much difference to me though.
Lee
2017 Nissan Leaf Tekna
Old 11th September 2014, 09:33 PM
Cheers Lee, good to know
