Old 6th September 2014, 04:26 PM
Mikey-S Mikey-S is offline
Default Which rear pads?
Hello all. I'll be replacing the brake pads on the S8 (2002) with Ferodo Premier. The front pads are easy enough, but there seems to be a handful of different rear pads to choose from. Any ideas which ones are correct? See this link: http://www.kimbercarparts.co.uk/brak...002/Parts.aspx
Thanks in advance!
Old 6th September 2014, 08:53 PM
You are right to be cautious.
Look on EKTA ...
http://www.partscats.info/audi/en/?i...234567890&hg=6
and check the PR-xxx codes in the parts list against those printed on your option code sticker in the service book or spare wheel well.
You then have the PR code and OE part number for you car, so keep a note of them.
Some brake part sellers list PR codes, or you can look up the OE part number on a cross-reference list.
Old 6th September 2014, 08:57 PM
That's great thanks. I have the PR code here, I'll start investigating.
Old 6th September 2014, 09:53 PM
Thanks, all sorted.
Fronts: 1KW - 1J0698 451H - Ferodo Premier number FDB1509
Rears: 1ZL - 4D0698151L - Ferodo Premier number FDB1788
