Old 25th September 2014, 10:58 PM
texas2201 texas2201 is offline
Default replacing drivers seatbelt
how do you (without damaging it) remove the trim around the drivers door aperture to replace the seat belt?
Old 26th September 2014, 08:31 AM
Here's the ElsaWin instructions - if you need any of the trim removal instructions let me know. It's a bit of a ballache to go into each link to print them off and most should be self explanatory once you've seen which bits come off in what order
Old 27th September 2014, 09:29 AM
Thanks Adrian - that is helpful but I need to see how the trim comes off the B pillar - it is not obvious to me!
If it is a pain if you point me in the right direction I could do it? Or is it something you have purchased?
Martin
Old 27th September 2014, 04:16 PM
Here you go - thought there was more detail included in what I'd posted already than there actually was!
Adrian
Old 28th September 2014, 12:41 AM
Thanks Adrian
Old 29th September 2014, 06:56 AM
Needed a new drivers seat belt as the old one was not retracting properly. How hard can that be? F**kin hard is the answer ..... Drivers seat out, trim from drivers and rear door out carpet pulled up, battery disconnected. Cracked head more times than I care to remember ...... Eventually job done ......
Old 29th September 2014, 07:57 PM
Old 29th September 2014, 08:56 PM
Ouch!
Old 29th September 2014, 10:16 PM
Norretal's Avatar
Norretal Norretal is offline
Not just me then
Audi TT - 2015 - Ultra
