Old 29th September 2014, 01:18 PM
Exerqtor Exerqtor is offline
Default 20x10" 50et
Does anybody have some experience with 20x10" on a D3?
(with 255x35 tires)
Old 29th September 2014, 02:32 PM
(with 255x35 tires)
10'' with ET 50 I think it will rub, unless you put 20mm+ spacers.
You won't be able to fit this tyre on 10'' wheel. Min on 10'' is 295 I think.
You better stick with 9'' or 8.5''
Old 29th September 2014, 02:46 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Don is running 20x10 on his A8.
http://forum.a8parts.co.uk/showthread.php?t=7813
But don't think they are E50, Like M-A8 said. They might rub.
Are you able to test fit before buying?
[center]
06 3.0TDI Quattro:
Options:
Old 29th September 2014, 03:19 PM
Hmm ok, that sux a bit. I have to buy the rims first
Old 29th September 2014, 04:49 PM
They will fit mate, but there are 2 requirements:
1) You will have to fit at least 20mm spacers (+extra long bolts) so extra cost on top.
2) Are you happy running on 295/30/20?? Cost of them will be probably higher as well when compared to 275/35 and 255/35.
You will have to go 30 profile with such a width on 20s
Old 29th September 2014, 07:49 PM
I get adapters for a very low price so that ain't a problem £200,- for 4x20mm.
The plan is to run 255/35 so the tire price ain't that bad. And if you compare the RUFF Racing to VOSSEN and so on i get almost all 4 RUFF rims for the price of 1 VOSSEN.
That taken in consideration the cost of a couple adapters is ok
Old 30th September 2014, 07:06 AM
mannyo mannyo is offline
There is a 25mm difference in the diameter of the tyre between 35 and 30 profile on 255 width.
255/35 on a 10" rim is going to be a LOT of stretch and technically depending on Norways requirement invalidate your insurance and type approval for the car.
Manny
Past
Old 30th September 2014, 07:17 AM
ScottD3's Avatar
255/35/19 on a 10j wheel.
275/40/20 seem to be a better fit.
[center]
06 3.0TDI Quattro:
Options:
Old 30th September 2014, 10:20 AM
NightOwl NightOwl is offline
If it's at any help, on my D3 with OEM 19x9 ET44 rims, it's about 22mm clearance between the tyre/rim and the wheel bearing housing.
Old 30th September 2014, 12:44 PM
I have to see how it looks when i get the car. But i think i want to space it out anyways to "fill" the arches better.
