Old 13th October 2014, 10:38 AM
Borys's Avatar
Borys Borys is offline
Default Exhaust sound upgrade?
Guys,
As this is my first a8 don't know much about it.
Had mercs before and to upgrade exhaust was easy, I knew what need to be done easy,quick and cheap
What would be a best way to get more burble from my v8, not too much
I want it to growl a bit more
On mercs I use to remove the resonator plus x pipe - left original muffler and it was enough for me
Any advise would be appriciated
Thanx
Old 13th October 2014, 11:57 AM
Hi Borys
It is a bit tricky. Removing anything increases the sound drastically.
Removing middle section and keeping original back boxes does make it sounds nice, but not very deep.
So I would start with back boxes first.
Here are some samples from stage 1 and 2
Both really loud so if I were you and wanted only a bit then start from the back and ask for not very loud boxes, I did because that's what I was after
check this threads, you will find there links to video clips.
http://forum.a8parts.co.uk/showthread.php?t=7206
here are some from the ADI. Don't think its as quiet as it sounds, its very misleading, its really really loud
from 25sec
https://www.youtube.com/watch?v=u_tOXYXZz94
mix of mine and Darren's with stock W12
https://www.youtube.com/watch?v=lt02UFuu_NU
Old 13th October 2014, 05:24 PM
Borys's Avatar
Perfect,
Yours sound quite nice :-), really like it
Thank you
Old 13th October 2014, 05:43 PM
Borys, be aware, it's VERY LOUD !!! Videos do not reflect the real sound level
Old 13th October 2014, 05:49 PM
Borys's Avatar
Check out my Jag S type Supercharged on Arden exhaust
That was amazing
https://www.youtube.com/watch?v=vMZc...zsquyuIOWqHFug
and my CL420
https://www.youtube.com/watch?v=W8ac...zsquyuIOWqHFug
Old 13th October 2014, 06:24 PM
That sounds very similar, but difficult to judge from the video.
Are you after a loud exhaust??
Old 13th October 2014, 06:50 PM
Borys's Avatar
No not really loud,
Just need to bring out that deep burble when giving it beans
would be nice to have it quiet on constant speed
That black CL was like that (resonator out and medium size back box)
On audi I don't know what to expect :-)
Why my stupid question in the first place
Your tread is very helpful, starting from back box
Old 13th October 2014, 07:03 PM
In this case start from the back boxes as you just said.
You could try CKS Performance in Harrow, they have a youtube channel with few D3s with new back boxes.
I would strongly recommend Hayward & Scott in Basildon, but that depends from how much you willing to spend to be honest...
Old 14th October 2014, 08:33 AM
Conquistador's Avatar
I've heard lots of good things about Hayward & Scott too.
On mine (when I had it), I removed all the centre silencers and kept the S8 back boxes and tailpipes because I wanted it to look stock. AMD in Thurrock, Essex did the work for me.
Made it burble nicely at low revs but was still able to drive it quite discreetly if desired, then as you went above 3,000rpm you got the loud ripping sound.
Here's a short video (cold start):
https://www.youtube.com/watch?v=HzyP...ature=youtu.be
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 14th October 2014, 08:37 AM
Ollie, long time no see, how's things??
I did love your exhaust
It was just perfect. The S8 boxes performed well much better than standard petrol ones without the center bits.
