Old 18th October 2014, 04:38 PM
jools_s8 jools_s8 is offline
Default Help locating Aircon High Pressure switch
Please can some help me by advising where the aircon high pressure switch is located? I need to disconnect it as the aux fan has failed on whilst I get a new one organised.
Not had any luck finding it's location on the forum / audi forum sites.
Thanks!
Old 18th October 2014, 07:44 PM
I believe it is where the pipe from compressor enters condenser radiator. But I don't understand the logic behind disconnecting it. It's there for safety to switch AC off if pressure rises too high.
Old 21st October 2014, 12:50 PM
Thanks.
The aux fan is killing the battery, hence disconnecting the switch will disable the air con and the fan from being on. I was going to disable the aircon until I can get the new switch fitted this weekend.
