Old 7th November 2014, 02:00 PM
Lloyd Lloyd is offline
Default Delta head unit info needed
Does this need a radio code , I don't have a manual or original service book and need to disconnect the radio to diagnose fault cd changer and install a parrot mki9200
Old 7th November 2014, 02:08 PM
Almost certainly. Various online services offer to get it for you for a fee, or try an Audi dealer if it was the original fitted to the car.
Often people write the code onto one of the labels on the unit, so try sliding it out (still connected) and have a look.
Old 7th November 2014, 02:24 PM
Or in the insude front cover of the manual. And, a few times, I've seen the sticker placed on the underside of the ash tray
Old 7th November 2014, 02:30 PM
Ahem.......
Old 7th November 2014, 04:07 PM
mannyo mannyo is offline
You should be able to sort the CD changer and fit the parrot kit without disconnecting the power connection on the back of the headunit. The power connection is completely separate from the speaker connection and the CD changer connection.
Manny
Past
Old 8th November 2014, 04:27 PM
when i slid out the unit this morning i noticed red pained " no code " on it so took a chance and sure enough its still fine , seems its not the factory fitment which might explain radio and cd changer not working
anyway all fitted but need to get patch lead to get rear speakers working on parrot .
