Old 19th November 2014, 08:22 PM
mazm3 mazm3 is offline
Default Air leaks?
Car: 1996 A8 4.2 auto
So im getting some **** poor mpg at the moment. Driving like an absolute OAP im getting 16.9mpg at best. Thats a mixture of 40 and 60 mph roads.
I have noticed a split (read hole) in one of the crankcase breather pipes. Now im not getting any engine surging or cutting out like you would normally associate with an air leak so have ignored it. BUT it leads me to start thinking it is upsetting the mixture?
Thoughts?
Old 20th November 2014, 08:07 AM
Have you given it a scan?
Old 20th November 2014, 05:40 PM
No, will do that first
Old 10th December 2014, 06:22 PM
Ok, so scanning brings up codes of mixture adaptation so im assuming the split crankcase pipe is letting in air after the MAF. So surely isnt the engine going to run a weak mixture with that extra air going in OR are the oxygen sensors picking this up and causing things to richen up
Going to replace the pipe/clear codes and report back
