Old 4th December 2014, 11:04 AM
pwacka8 pwacka8 is offline
Default HELP!!!!!!!! 4.2TDI not starting
Hello All
Just putting my 2007 4.2tdi on the road, it was a damaged repairable , repaired the body damage last saturday and it went to VOSA for its VIC check on Tuesday , the car has started fine since i got it , it hasnt done many miles as i cant tax it until VIC marker is removed , however my Dad took it to the VIC check for me , started in the morning no problem ,drove about 5 miles to VOSA and parked up , booked in and then was told to move car into garage.
He said it took a couple more turnovers that usual then started up and everything was fine, VOSA checked the car and then come to start it and the car would just turnover with no sign of life.
Had to get it recovered back home , initial investigation i found that the battery was only 77ah and was rubbish , im hoping its just the battery . i dont think it was coded to the car as its been sitting a while before i got it and i think someone has just thrown a battery in to get it going.
If it isnt the battery does any one have any ideas , i believe that the crank position sensor can go and that would cause similar issues of the engine just turning over with no life.
I scanned it last night but under engine in vcds but the only code found was check abs controller or something along those lines.
I will be coding a new battery on and rescanning it this afternoon so any ideas would be greatly appreciated as i havnt even drove it on the road yet !!!!
Could someone post the location of the crank position sensor from ETKA as i have found etka online but the 4.2tdi isnt included?????
Thanks in advance
PWACKA8
2012 4.2TDI SE EXEC
Old 4th December 2014, 06:06 PM
mannyo mannyo is offline
When you replace the battery the car is going to end up littered with fault codes. Replace battery and code it, then scan for faults and clear them all. Now try and start the car, if it does not start scan for faults again.
Manny
Past
Old 4th December 2014, 06:45 PM
Hello Manny
Thanks for your reply
I fitted a new Bosch s5 110ah Battery tonight and then coded the battery ,once complete i cleared all the codes and then got out locked it and then unlocked and tried to start it , no joy , just kept spinning over , didnt even splutter.
Then read codes again
CDS Version: Release 12.12.0
Data version: 20130910
Thursday,04,December,2014,15:36:47:62939
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 18 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 67 6C 72 76 77
VIN: WAUZZZ4E77N016939 Mileage: 143620km/89241miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Part No SW: 4E1 910 409 B HW: 4E1 907 409 A
Component: 4.2L V8TDI G000AGMª0010
Revision: --H04--- Serial number: AUX3Z0G0315682
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 23450907E2202306A91-8076
1 Fault Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 22:35:42
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Bin. Bits: 00101000
Torque: 468.0 Nm
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 S HW: 09E 927 156 B
Component: AG6 09E 4,2 TDI RdW 0010
Revision: --H01--- Serial number: 0101837
Coding: 0000001
VCID: 3365F94752C0B386591-8066
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224B0C03FD3A2A0EA27-8077
2 Faults Found:
00532 - Supply Voltage B+
000 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G0315682
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 A HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 300BS077578755
Coding: 0000002
VCID: 2A5BE423850AF24EEA7-807F
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000031417
Subsystem 3 - Serial number: 0116.02.070000000100010022ÿ
Subsystem 4 - Serial number: 010022ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000114701
Coding: 0022529
VCID: 1C3732FBDF5E1CFE68B-8049
5 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 254
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 00:02:37
Freeze Frame:
ON
Bin. Bits: 00011111
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.23
Time: 01:30:27
Freeze Frame:
ON
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:16:45
Freeze Frame:
Voltage: 8.60 V
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 2
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:31
Freeze Frame:
Bin. Bits: 00001111
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 2
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:31
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: E5C1D71FEC949D36875-80B0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 9
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:28
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0010
Coding: 0011773
1 Fault Found:
006217 - Please check DTC Memory of Transmission Controller
P1849 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.12
Time: 00:29:33
Freeze Frame:
RPM: 84 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
(no units): 0.0
Voltage: 6.61 V
Torque: 795.6 Nm
Bin. Bits: 11000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H14 4210
Revision: 91H14421 Serial number: 0037P0G07NUP
Coding: 0431707
VCID: 275D1D179618CF26F59-8072
Subsystem 1 - Serial number: 63328RB40219F787R
Subsystem 2 - Serial number: 63428RB40219F21AJ
Subsystem 3 - Serial number: 63528RB40219F2D1N
Subsystem 4 - Serial number: 63628RB40219F211C
Subsystem 5 - Serial number: 63729RB40206046CD
Subsystem 6 - Serial number: 63829RB40206046BD
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 0
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
02095 - Component Protection Active
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01316 - ABS Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 1
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 23:28:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 46
Reset counter: 8
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.25
Time: 00:02:30
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0112141
VCID: E5C1D71F2C949D36875-80B0
Component: Lenkradmodul H07 0090
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 57
Reset counter: 8
Time Indication: 0
Date: 2063.15.31
Time: 31:63:18
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 8
Time Indication: 0
Date: 2063.15.31
Time: 31:63:02
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 8
Mileage: 0 km
Time Indication: 0
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 B HW: 4E0 920 951 B
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3G1000959
Coding: 0000413
Shop #: WSC 00414 210 91518
VCID: 24470A1BE72E243ED0B-8071
3 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 8
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.12
Time: 00:16:51
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 8
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.12
Time: 00:16:51
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 9
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:03:05
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3B34E3D56A62CE7A7-804F
4 Faults Found:
00664 - Fuel gauge
00456 - Control Module for Access and Start Control (J518)
01407 - Flame Extinguished
000 - -
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0712581DF
Coding: F5D9DFFF70720E
VCID: ECD7A23BCF7EAC7ED8B-80B9
Address 1E: Media Player 2
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
1 Fault Found:
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:15:34
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 C HW: 4E0 907 289 C
Component: Komfortgeraet H09 0020
Revision: 00200009 Serial number: W040702150086
Coding: 0004317
VCID: 29591B2F800CF956E3D-807C
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Time: 00:15:40
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000105411
Coding: 0010101
VCID: 1E3338F3C9420EEE86F-804B
2 Faults Found:
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:20:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2013.04.04
Time: 00:16:00
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000006
VCID: 3D71DF7F648475F6BF5-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396BY077560494
Coding: 0000001
VCID: 2E53E833B9E29E6E36F-807B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000001232
Shop #: WSC 00353 210 91471
VCID: 204F060BF336381EB43-8075
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 0092S50150
Coding: 344530393135313035412056413030303932533530313530
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028462
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000702050031
Shop #: WSC 12336 024 394758
VCID: 3663C05341B2A6AE7EF-8063
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J72106G
Coding: 1020302
VCID: DCB7F2FB1FDEDCFE28B-8089
5 Faults Found:
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 00:01:28
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 76
Reset counter: 9
Mileage: 143600 km
Time Indication: 0
Date: 2013.01.25
Time: 00:02:15
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
02203 - Audio / Video Input 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 143600 km
Time Indication: 0
Date: 2013.03.22
Time: 19:46:44
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 9
Mileage: 0 km
Time Indication: 0
Date: 2013.01.28
Time: 00:00:34
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
013 - Check DTC Memory
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 0
Mileage: 184232 km
Time Indication: 0
Date: 2013.01.21
Time: 00:01:28
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Can any one spot anything??????
My missus is getting a bit cheased off with me know as with 4 young kids shes not happy with me taking her car to work and now the car has passed the VIC check i can tax it if i can get it to the MOT station so i can actually drive it!!!!
My plan was to be using the car by now and posting a thread with my progress getting it all sorted , not trying to get it started ???
Now i have my VCDS working if i can help anyone in the northwest give me shout!
On another note big thanks to CARL for sorting my parts out , quality service from A8 Parts ,recommended no problem!!!!!!
2012 4.2TDI SE EXEC
Old 4th December 2014, 06:48 PM
did you do an auto scan then a full clear of the codes as some battery replacement ones still seem to be present along with some really old faults from 2013.
Manny
Past
Old 4th December 2014, 06:51 PM
I did a auto scan then cleared all codes then turned ignition off and locked and unlocked car then ignition on and done another auto scan?
2012 4.2TDI SE EXEC
Old 4th December 2014, 07:07 PM
Sir WIll Sir WIll is offline
There is a lot more in there than I would expect after it has been cleared down.
Either it needs a clear down again or there is something more. Almost like the wiring/ earthing has a problem which is unlikely on a modern car.
Old 5th December 2014, 08:29 AM
It's throwing an error on the power management module. That can cause all manner of horrors.. Has someone jump started it wrong?
Also an error on the oil pressure sensor, not sure, but if that's throwing a wobbly, then the car may not fire in order to protect itself.
Old 5th December 2014, 11:15 AM
I have heard about the power control module before , i take it its not option 61 in vcds battery control? is there a way to test the module with vcds?
Im hoping to get home handy from work so i can go through all the fuses and check them.Can anyone point me to the location of the power control module?
thanks again for all your posts so far!
2012 4.2TDI SE EXEC
Old 5th December 2014, 11:18 AM
PsYcHe , just thought , yes the vosa guys tried to jump it before they let my dad now it wasnt starting , mmmmmmm
2012 4.2TDI SE EXEC
Old 5th December 2014, 01:07 PM
So.. the battery may have died.. if the D3 isn't jumped properly, it can (and probably will) fry the power control module.
