Old 4th December 2014, 03:44 PM
OwwDee OwwDee is offline
Default 4.0 TDI valve rockers broken
I have a problem with my 2004 A8 4.0 TDI Quattro.
Started her up one morning last week and there was a strange noise
from the engine bay. I was at my workshop at the time which is 1/2 mile from my house.
I had driven the car from my house to the workshop an hour earlier without any problem.
It was cold, car was covered in Frost.
I gingerly drove it back home, and got my mechanic to come have a look.
We started her up, and it seemed that the left 4 cylinders were not firing.
Loaded her onto a flat bed and brought her to his garage, and on inspection it was found that several valve rockers were broken.
Have any of you experienced this or anything similar?
My mechanic says that he has seen this problem before on the 2.5 litre engine but not the V8.
I will of course be rebuilding the top end with new Rockers, Lifters, and while I am at it new timing chains and timing gear.
This of course is an engine out job as the timing chains are at the rear of the engine next to the bulkhead.
What could have caused this? What else needs to be done while the engine is out?
The engine has 206,000 miles, and she has service history.
2004 A8 4.0TDI Quattro
Old 4th December 2014, 05:55 PM
mannyo mannyo is offline
The 4.0TDI is not exactly renowned for its reliability, the intake manifold flaps eventually break and are then ingested into the engine resulting in engine failure. The same thing could have happened to you, something could have got into the cylinder which caused the valve to stick in the open position, thus breaking when the cam was unable to press down on the valve.
http://forum.a8parts.co.uk/showthread.php?t=5029
If the flaps have failed then they are the best part of £1K to replace, you'll need to remove the intake manifold itself to check the flaps are still intact.
Manny
Past
Old 4th December 2014, 08:25 PM
If manifold flaps brake and go in the engine, then get trapped between up going piston and down going valve that could generate enough force to brake rockers.
