Old 1st February 2015, 09:22 AM
Laisvydas Laisvydas is offline
Default Car boot wont open, how to get in?
Hey, I've got a problem, audi d2 facelift boot got stuck, i closed it last night as usually, today i cant open it any more, i tried to push the button on the remote key, boot el. motor doesn't sound as normal, i can hear noises from it, but it sounds as almost dead, so that means a problem, i have no idea how to open audi boot, any ideas? Thanks.
btw sorry for my english.
Old 1st February 2015, 10:01 AM
Sorry couldn't resist that, I'm sure someone with experience will help soon
Old 1st February 2015, 11:21 AM
What happens when you use the key in the lock?
Old 1st February 2015, 07:39 PM
nothing, i tried to put the key in the lock and push it, turn the key in one direction, in other, then push it and other possible stuff with it... maybe it is possible to get inside from the interior?
Old 1st February 2015, 08:33 PM
Sounds like the rod across to the latch is disconnected if the key doesn't work. Or the actual latch mechanism is broken/jammed.
It's not the most complex/sophisticated setup, based on my memory of replacing a faulty latch. But getting at it is a different issue....
Old 2nd February 2015, 08:18 AM
Have you tried both locks, driver's door and boot?
Old 2nd February 2015, 05:01 PM
yes, i tried, thanks, everything is alright with driver's door lock, key doesn't work only with boot lock. Hpsouce thanks for information, ok then, now i know why i cant get in, but next question is how to get in? is it possible to remove rear seat or smth and get in from interior?
Old 2nd February 2015, 05:34 PM
There's a solid aluminium panel behind the rear seat, but.......
There is a small panel for the ski hatch, largely cut out with just a few lugs holding it. You can access that from inside the car and cut it out, probably without even needing to take the seat back out, through the armrest hole.
I cut mine out easily enough, but from the boot side, to fit a ski hatch.
BUT it's not very big, covered with an adhesive black material on the seat side and there's a tough felt-like panel clipped on the boot side.
And once you've got access I'm not sure it would help as the latch mechanism is still pretty inaccessible and you would be poking tools from a long way away.
I wonder if a call to A8parts would help, they know exactly how these machines are put together.
Old 2nd February 2015, 05:52 PM
Ah I see. Sorry, I misunderstood/misread.
In that case, I'd second HPsauce's suggestions first.
Failing that, if there's no non-destructive way in, I'd be look for a way that minimises the damage .... perhaps by cutting the bottom off the spare wheel well?
Old 2nd February 2015, 06:13 PM
Well I would be asking an expert first before doing anything, but I would have thought one way in would be taking off the numberplate and going in there somehow.
