Thread Tools
Display Modes
Hello
I've had regular fault codes coming up for my S8, namely 02596 - Rear Brake Pads Worn 008 - Implausible Signal and 02438 - Right Parking Brake Motor Hall Sensor 008 - Implausible Signal - MIL ON which I can't clear. I've just done discs and pads, done the full VCDS adaptation process for the pads and the function test several times, all of which has made no difference, the brake works perfectly, voltages across both calipers are good. I've checked both connectors, both were immaculate inside, I've continuity checked between the control unit and the caliper, again all good. Any suggestions/thoughts before I invest in a new caliper? It's only done 49K and looks nearly new........ Sir Wil, can I have my D2 back????????? ![]()
1988 Audi 90 2.2E 2011 Mercedes E250 2016 Abarth 595 Competizione 2012 Porsche 981 3.4S PDK mid life crisis! |
