Getting a rumble from the ffront passenger side wheel bearing. Been getting worse over the pass few weeks I find that I get the sound most at between 15 to 18 mph when slowing down and also right head turns at round abouts
tyres have been replaced so there all good has anyone had one replaced and have an idea of cost thanks for the help Steve Last edited by 3.7 slp; 14th February 2015 at 12:56 PM. |
My old S8 had the bolt on type which saves removing the upright to press the bearing out in the other - if yours has this type it will take half the time or less.
However, if you have the press in type, the upright needs to be removed, you will also need to remove the pinch bolt holding the top arms in place which (if ALu upright) not an issue as rust weld not present, but the normal steel ones can be a major PITA, so take it someone who has done a few, as like everything, experience helps! |
