Old 5th March 2015, 12:56 PM
kmthor kmthor is offline
Default more problems
ok so last night coming home the lights were on auto and when they kicked in the light fault light, the esp fault light and the break light came on . Could this be because there was a drop in voltage when the light was turned on? or somthing more sinister?
km
Old 5th March 2015, 01:35 PM
That's sounds like a problem with the earthing from the ballasts.
Old 13th March 2015, 12:50 PM
do you know were the earth is for the ballasts? it happened again the other day
same warning come on if you leave it a while they dont come back
Old 15th March 2015, 12:06 PM
Are you sure it was linked to the coming home lights switching on or could it have just been similar timing? Sometimes what you described can be triggered by a faulty brake switch on a D3 which is about £6-7 cost and quick to change so may be worth a look
Old 17th March 2015, 02:25 PM
when i say coming home lights what i mean is the lights are set on auto and when they come on it happens but nit every time thats why i think its a load issue on the battery. but i dont really know
