Old 7th March 2015, 10:43 PM
carmel120 carmel120 is offline
Default parking sensor
hi my front parking aid is not working done a scan and there is no fault codes and everything seems ok is there a way to switch them on or check
cheers trev
Old 8th March 2015, 08:21 AM
mannyo mannyo is offline
Do you get a long high pitched beep along with the flashing green light when you select reverse or press the button on the dash?
The controller will detect a break in the circuit of a faulty sensor and disable both front and rear sensors.
You could use VCDS to check the measuring blocks and see if the front sensors are actually working and picking up a signal, in which case it could be the sensors speaker that has failed.
Manny
Past
Old 8th March 2015, 06:45 PM
hi when I select d or r I get one beep then nothing and no flashing green light.how do you check the measuring blocks I think mine says 255 on all of them.
cheers trev
Old 9th March 2015, 09:32 PM
done another check tonight no fault codes no flashing green light both front and back not working im getting one beep if I select D or R done a reset of the mmi should I do another mmi upgrade run or would this clear things on the display
cheers trev
Old 9th March 2015, 10:24 PM
I have never done it before but I would think you would need someone to walk around the car so you can see if the sensor values change
Old 10th March 2015, 10:50 AM
cheers trev
Trev
One of mine is faulty, and the easiest way I found to test it by myself was pretty simple. Call up the measuring block in VCDS. As you say, they all show 255. Next, just attach a piece of paper to the bumper so that it covers a sensor. Then check VCDS. If the sensor is working, it will show 0 and not 255. Then just repeat the process on all the sensors. Mine is a front centre fault, which means a bumper off job, which I'll get around to... eventually.
Old 10th March 2015, 06:04 PM
cheers guys done a bit searching and I got this code in 19 can gateway
1327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication - Intermittent
cheers trev
