Old 18th March 2015, 09:50 PM
richardracer richardracer is offline
Default D3 folding mirror stuck up after bump
Hello all,
My car was bumped whilst parked and the drivers door mirror has been jammed (?) in the up position. When I try and restore it to normal position on the door control, it moves very slightly then stops, maybe 2 or 3 mm.
I have been into VCDS but I cannot find any reference to the door mirrors (hoping there might be a reset(?))
Does anyone know if there is a way of resetting mirror back down? If not, what is the cost of a new mirror?
Thanks to the experts
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 18th March 2015, 10:19 PM
Work it manually by hand back into position.
Old 19th March 2015, 02:43 PM
Agreed - If it was knocked manually out of position, move it manually back. They are designed to be knocked out of position for this very reason. Once clicked back onto its rightful position, all should be well...
Old 19th March 2015, 08:31 PM
Default Drivers door mirror
Hi guys,
My Indy has pushed the mirror back into normal position. It does not fold and it no longer adjusts from the switch. Does anyone have a diagram of what is inside please.
Richardracer
Old 21st March 2015, 01:29 PM
Not to hand but its fairly straight forward. Check your fuse, then check you are getting power to the adjustment for mirror mech.
This is a half elipse unit (secured by x4 mini torx) that adjusts the mirror that can be removed, cleaned or replaced. Then there is another motor which does the mirror folding mech.
The forum sponsors will be able to provide you with a complete unit if they are both caput. The mirror adjustment unit can be bought separately from Audi.
