Thread Tools
Display Modes
Hi All,
Does anyone know what size/thickness front disc I have on my car. The code in the service book shows it as 1KE, which I believe is the 269mm size disc. Are the disc the same size for the front and rear, as my fronts are well worn after 170,000 miles of use and need replacing urgently. There is also heavy squeeking on normal braking coming from the fronts Also, can anyone recomend cheapish Branded replacements from Euro Carparts Thanks, David ![]() ![]()
2002 S8 Final Edition, Avus Silver with Red leather interior Guildford, Surrey Tiptronic with Sport mode button. Sony rear entertainment package. Bose sound system. Audi Navigation Plus. 20 inch Final Edition alloys Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() ![]() 1997 A8 Quattro Sport - Now sold when S8 FE purchased ![]() |
Front disks will be either 323x30mm or 314x30mm, 323mm was used on S8 and some A8's, 314mm was usually used on smaller engine cars. Rear discs will be either 269x20mm or 245x10mm more likely to be the bigger option, if they are vented they will be 269x20mm, on the front only 100% sure method is to measure them, 1LC should be 314mm, 1LX 323mm but I would not trust it 100% without measuring.
Wit the the current exchange rates to euro it makes sense to check German prices. I recently replaced fronts on mine, cheap and decent front pads for 323mm front discs here: http://www.ebay.co.uk/itm/1412284893...%3AMEBIDX%3AIT I went for coated zimmerman discs to slow down corrosion if you need 323mm here: http://www.ebay.co.uk/itm/1816037995...%3AMEBIDX%3AIT
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 19th April 2015 at 12:30 PM. |
Many thanks ainarssems.
Have ordered the correct ones now 314mm. David ![]() ![]()
