15th March 2017, 10:31 PM
Originally Posted by HPsauce
Photos might help, but if I understand you correctly your standard mirror has a single plug (how many connections?) but the new auto-dimming one has two plugs, the extra being small with 6 wires?
As I mentioned long ago (actually in the thread you linked to) the auto-dim interior mirror only really needs power and earth. Power from a "lights on" circuit would be ideal and you probably have that available already if you can identify it. And earth should be simple.
Correct. The single plug has four connections and plugs into the reading lamp section. I'm opting to go the non-OEM way and just go with the + and - wires.
