That might be a good option, although those two wires are a biy heavier than most of the wiring, so may interfere. From memory, the bonnet release grommet is about one inch in diameter. According to the wiring diagram they are 4.0, which might mean 4mm2, but I'm not sure if that is correct. There is a third wire that you can see in the photo that I got from eBay (surprised at how cheap the modules are) which is very thin, and that goes to the climatronic unit.
