Old 4th March 2023, 09:24 AM
Originally Posted by Julian Thompson View Post
Does anyone know the procedure for coding this up if I fit it?
That link I provided in post #4 above goes into the coding side of things. Reading through it, the possible issues are the initial login code (do you use your existing code or what the new code is), and also running the Basic Settings to get the code to stick.
In terms of your car, and the image in the third post on that thread, I think your new code should be 05727 i.e. A8 SWB, Brembo, 6 Cyl Diesel with Brembo, Automatic. There is also a Note at the bottom of it to recode the Control Module.
As before, it will makes things easier in the future if you update your signature to include details of the car, so that we know exactly the spec, and don't have to keep asking specifics. Keep up informed on how it goes, and even provide a write-up of the procedure, as it might help someone at some point.
