Originally Posted by donp38
Is the thermostat a timing belt off job?
From the work I've done on the car, I would say a definite yes, but I do recall seeing a post somewhere where they said they could do it without removing it, by just prising it forward, which I reckon would be very tight and need multiple hands.
If you look at image 688, I've highlighted where the thermostat is, behind that metal pipework. Image 423 shows what's in front of 688, and image 680 shows what's in front of 423. Take into account that I also had the entire front end off the car, but I needed to do that. This is a 3.7 engine, but the 4.2 has a very similar layout.
EDIT: Found the link, with video, but the engine is out of the car!
https://www.audiworld.com/forums/a8-...-belt-2909229/
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
