Originally Posted by danyalmakda
3. Looking for the gloss triangle trims on the rear passenger doors - does anyone know the part number??
Left outer 'corner trim' - Brilliant black - 4D0853273 Y9B
Left outer 'corner trim' - Black - 4D0853273B 5PV
Right outer 'corner trim' - Brilliant black - 4D0853274 Y9B
Right outer 'corner trim' - Black - 4D0853274B 5PV
You have to dismantle the door and remove the top section to get access to it. For those who have done it, they usually just sanded down the original and repainted. Check out the following PDF located in the
D2 Common Faults >
D2 Tech Dump thread (lots of excellent PDFs), starting at page 81:
Service Manual General Body Assembly Exterior (Rep groups 50 55 57 58 60 63 64 66).pdf
If attempting this yourself, when removing the door card, there is a very small clip securing the bowden cable to the interior door handle. Try not to lose it (MikkiJayne has 3D printed replacements). The top section of door is held on by four bolts. Mark their position before removing for later when refitting. There is also a metal shim, which again you should mark the position of.
4. Sunroof doesn’t open when control fully turned open- need to turn it half first then full to make it open - tilt function works fine
With it having sat for 6 years, hopefully the tracks just need lubricated with someone like lithium grease.
While you're here, pop along to the
Introductions page and introduce yourself. It's also worth going into your
User CP (at the top left of every page) and add some details like your location (handy to have if looking for help in your area) and also a signature, where you can add details like spec of car (ideal when posting a question, as then we don't have to ask about the spec of your car).
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
