Originally Posted by IT D3
I can also hear the compressor cycling a time to time, I'm not sure if the mechanic has mounted the compressor incorrectly and it is fouling something. I know it is mounted on a special insulating kit - perhaps he's done something wrong here.
From memory when I replaced the compressor on mine, the compressor mounts to the isolation frame with three mini 'shocks'. Essentially, it's a rubber T-shaped grommet and a spring, and held in place with a bolt. The isolation frame is then bolted to the car with another four bolts. So far as the mechanic fitting it wrong, unless he left out the springs or the grommets, I can't see how it could be fitted wrong.
Reading through the previous posts, is it possible to get it scanned again to see if you're still getting the over temperature code, as I'm wondering if this is why the other options are greying out, and that although the compressor is giving you the 16 bar output, maybe there is still another leak somewhere.
Finally, others including Neil suggested getting the fuse and relay replaced. Do you know if this was ever done for definite, as it's standard practice to replace both when replacing the compressor, irrespective of their condition, and it's not the hardest job to do... just lift up the passenger footwell carpet, remove a piece of moulded polystyrene and replace them.
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
