17th March 2019, 06:57 PM
Originally Posted by rory_pamphilon
Following this post as I too have constant brake pad warning indicators on, have got quite used to it to be honest but if the MOT is going to start checking it I will have to do something about it.
Just out of curiousity, is the MOT going to test its function or just whether the warning light is on or not? i.e. if the light is off, is that an instant pass on that part or will they simulate a worn break pad check to see if the light functions ok?
I'm not so sure they would start testing this. After all, it is just an indicator warning that the pad is getting low, and with our brake pads, the warning comes on when there's about 50% of pad wear left. I had a similar problem after replacing my pads, and never got to the bottom of it. Ironically, when I started using the car (after it sat for 7 -8 months), the calipers were seizing, and I ended up cooking one of the pad wires. Now that the calipers are working, the indicator light isn't on permanently, so it's just not a snug connector somewhere.
