19th February 2018, 09:15 AM
Originally Posted by pete-p
I didn't scrape a single knuckle either! Time will tell if it stops the water ingress or if the drains are also blocked, but it looked fairly clear of water in there.
You must have done it wrong if you didn't even scrape a knuckle. If a job is worth doing right, it's worth bleeding for.
