Old 4th November 2018, 02:10 PM
I had issues with the passenger side on side just prior to the MOT. Tried the needle method, but it didn't help. What I ended up doing was removing the tubing from the jet, and then using a small syringe, forced hot water back down the jets, which cured the problem. I suspect that over the years, gunge somehow accumulates at the base of the jets, blocking them. By forcing water through them the wrong way seems to clear them.
